The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
I figured if you pull the oil housing off the block can you then get to all the bolts you need on the cooler and NOT have to break the waterlines, then replace the 2 oil seals?
Yes it would just make.sure you don't have any mods or they will void your WarrantyI have the same issue at 94000 would this be covered under warranty?
don’t you need to bleed the cooling system afterward if you introduce air into the system?? and don’t you need the dealership to use the electronic tool to open the thermostat??,
I have this leak too on a 2018 with 60,000km. So... this is gonna be a recurring issue? I don't see why it won't just fail again.
I replaced my oil filter housing/cooler in Jan 2023 @ 135,000km (it was leaking badly and left a small pool of oil on ground) and now my new one is starting to show signs of a minor leak again @ 160,000km. Wtf
This issue should be recalled itemWow, only 25000KM later and it's leaking again.
Wouldn't it have to affect a majority of owners? Or leak oil directly on the turbo to cause a fire hazard?This issue should be recalled item
There is a recall on the turbo leaking and causing fires.Wouldn't it have to affect a majority of owners? Or leak oil directly on the turbo to cause a fire hazard?
Exactly, not for this issue that doesn't leak anywhere near the turbo.There is a recall on the turbo leaking and causing fires.
I agree, if this is a known problem for every Stinger owner I don't see why KIA does not have a recall on it. I guess, the way recalls work is that owners have to start a lawsuit to KIA and when they see that there are many complaints about it, that is when KIA is forced to recall.Exactly, not for this issue that doesn't leak anywhere near the turbo.
That's weird. But they should make one.How come you can get a METAL oil filter housing upgrade for other 3.3 hyundai motors but not this one???
Finally did it today.
It was the gasket that is between the oil cooler and oil filter housing. Job is a pain, but you do not need to drain all of the engine oil or coolant as the manual says.
Having the front of the car up on ramps then just draining the oil filter housing no other oil will leak out. Then 2 hose clamps on the oil cooler lines stops the coolant from coming out. What you see in the pictures is whatever coolant was left in the cooler
