Finally got around to doing the LEDs conversion. Robz32 instruction really helped and so did his list of tools required.
The only delay as some others have pointed out was trying to disengage the connectors. I couldn't release them until i had the light bar at out a bit and unclipped them from the top side with the long nose pliers. It was the pliers that surpressed the holding clips that i otherwise couldn't see.
All else was easy i had to tear the foam as instructed to release the tension on the wires so i could get the bulb and holder out straight. Putting the wider leds in meant the holder and leds had to be put in straight it was a tight fit but all went well.
Yes i got the third tail light its known as "Convoy" the finish quality is absolute sh#t. I bought it here from.one of the advertisers. I had to get it sanded back and repainted that alone cost me $200aud cash.
I got an auto electrician to fit it, he did a good job. I wouldn't do it myself and im glad i didn't. I love the look.
Pm if you want to know more im over shaming them for the product quality. And i haven't.
Unfortuntly i had it fitted before i could see in bright light where the mark was.
Simple directions to follow, notes on potential gotchas especially helpful. First little tweak accomplished, on to the Injen CAIs later this week or next.
great write up.
Thanks, i just purchased from Amazon: LUYED 2 Extremely Bright 1600 Lumens Backup Reverse Lights 921 912 W 16W 3020 30-EX Chipsets, Xenon White, No Hyper Flash
great write up.
Just installed these and everything worked perfectly!
Tips:
- Use a pair of latex gloves and you can avoid having to wipe fingerprints off of everything
- Lay a clean towel or array of clean paper towels down in your truck for you to lay your taillight assembly on without scuffing it.
Just did it - and after foolishly removing 2 black nuts and 1 silver nut per side and wondering why it wasn't coming off... Looked closer and found the 3rd black nut on each side. After that, piece of cake.
Lights work correctly - auto hold is AWESOME for checking this. Close door, start car, put in R, activate "auto hold", get out and look!
Ordered up the Sylvania ones from Amazon. Installed them today. Fired up the car and neither one worked. Had to rip them back out and installed the original bulbs back in. Returned the Sylvania to Amazon and ordered up the Luyed chips mentioned earlier. So I get to do it all over again tomorrow. Got to love one day shipping from Amazon.
