DNA is Digital
The answer is literally one post above your post .... Get an aftermarket remote start like compustar.. It will not turn itself off.
And its cheaper... oh and compatible with DroneMobile.
Which remote start did you buy that turns on the defroster and heated seats? Does your aftermarket have any other cool features?I went aftermarket also. Wanted to be able to turn on the defrosters and heated seats. I got the one with the app or fob start..it wasn't much more than the dealer wanted for the factory one. Doesn't shut off when you open the door and will run for 25 minutes without shutting off.
True ... but which remote start did you buy??? Shopping hard for the best options. Yours sounds nice!It's pretty sad when the after-market product can do more than the OEM, including the KIA UVO phone app for those of us with cars with telematics. It can tell me where I left/lost my car in a mall parking lot, but cannot turn on seat heaters or coolers with the remote start!?!?!?!
Went with the nustart with the phone connectivity option. .. the only other cool feature it has is the GPS tracking, can see where the car is at all times.Which remote start did you buy that turns on the defroster and heated seats? Does your aftermarket have any other cool features?
Nope, only Canadians can do that.So is there currently any apps out there that allows you to start your stinger with your phone off factory remote starter.
Wow, I had no idea I could recalibrate it for the cold environment, having to start it 2-3 times in the cold is certainly annoying. Will definitely try this tomorrow.I recently had a Compustar (CM7200) T12 installed with Drone. I had Aux1 wired to my front heated seats and steering wheel, and Aux2 wired to my seat cooling. $849 + tax. So far it works well, and I love the features, but I did have a few quirks.
My installer forgot to enable option 2-04 (trigger start). This means three clicks of the OEM KIA Lock button won't start the car. I'll get it updated next time I'm in.
I noticed that on sub freezing days the remote start would take two or three tries to start. I'm pretty sure this was because I had my remote start installed on a warm day, and my tach was calibrated under those conditions. I recalibrated the tach on a cold (sub freezing) start and it seems to work perfect now ( Why does my vehicle attempt to start three times but fail? )
Lastly, the Drone system stopped working after an update and I had to power cycle the unit, but then it updated fine and seems to be working well. Time will tell how it holds up, I'm signed up for 5 years of premium service.
I was considering having my rear defrost wired in, set to automatically trigger when I remote start and the car is below freezing, but so far I haven't needed that at all.
I'm going to use my car as it is for a while, and potentially add defrost in when I get the ISG (Idle Stop and Go) and Auto Hold memory module and Proximity lock module from Shark Racing installed.
I did notice that while the car is remote started, the automatic smart trunk opening doesn't seem to work. It beeps 3 times like it senses I am there, but will not actually open the trunk. I can still open it with the button on the hatch or my remote. I need to investigate this more, but I don't consider it a deal breaker.
When remote started, I can walk up to the car, unlock it, open the rear door, drop my backpack in, close the rear door, open my door, get in, close the door, and press the brake to takeover just fine.
The biggest issue I had was either bumping the brake while getting in, or being impatient and pressing the brake pedal before the door was fully closed. Now that I've learned the procedure, takeover works well.
While keeping your foot on the brake, press the remote start button on your remote control
So, an update (it's been a while!). I tried re-calibrating as you mentioned and while that worked, it didn't really improve my situations. Still was getting false starts in the cold or if it had been idle for a while (12+ hours).I calibrated my tach at high idle (1500 RPM). If you are using a Compustar brain and don't have a dedicated remote start remote, I think you could press lock 3 times to trigger the remote start signal or use drone to send the signal. Just keep holding the brake until you see your lights blink once to know the Compustar got the signal and learned the tach.
Side Note: I think drone may currently have a bug where if you place a POI alert inside of a Geofence alert you can crash your Drone device. I cleared my POIs and geofences and haven't had a problem yet (fingers crossed). The POI and Geofence features aren't super useful to me, but I had been testing them out.
...I ended up taking it back to the place that installed it...
I'm willing to bet they did what Compustar mentioned to do and removed the tach sense and just do static starts. I haven't had a single false start since I posted that.I started getting false starts when it was just a little bit above freezing. I brought the car in, they did a firmware update to the compustar module, and now it's working reliably. Not sure what if any settings they changed.
I never felt a need for wiring in the defrost, I mostly park in ramps or garages, so it never became a concern. Having the seat and steering wheel wired into Aux 1 and 2 has been nice though. This summer I will try the cooling functions.
The smart trunk still behaves the same, if remote started the trunk won't automatically open. Still does the countdown like it senses I am there, but then doesn't pop open. Not a deal breaker, but it's fooled me a couple of times.
I should also report that the Proximity lock module shark racing sells works fine with a Compustar system, no weird interactions there. The only thing to keep in mind is that if you unlock your doors (proximity or via key), the smart trunk won't even try to open (remote started or not).
