The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Yes but it took an aussie satellite dish to relay signals to get you there!.. and AUS has put exactly how many men on the moon?![]()
That’s trueYes but it took an aussie satellite dish to relay signals to get you there!
I had the same problem but bought a inexpensive polishing machine. Using compound it did the trick.I'm experiencing the same issue. Tried using a compound of two different brands to no avail... It doesn't even seem like a clear coat issue; more of a pair defect given that the compound does nothing and it feels perfectly flat when I run my finger over it...
Any thoughts?
I haveHas anyone put the “E” badge on the back also?
View attachment 18748 View attachment 18749 View attachment 18750 View attachment 18751 If you remove the rear badge...I’d say there is a 50/50 chance the paint chips. My auto body shop chipped the paint. They ending up having to repaint the whole rear piece. After painting they installed the 3 badges. Luckily it only cost me $50!
If this happens to anyone else, get some menzerna fg400 and a yellow pad on a da polisher and after about 8-10 passes with firm pressure, wipe down and examine. Keep doing this until its cleared up. One the scratches are cleared get a white pad and repeat the process with medium pressure and the last 4 passes light to very light pressure. If she’s doesn’t work you are looking at wet sanding with 2000-2500 grit sand paper, then running over it with fg400 with a white pad. I could fix that black panel pictured in 20 min.Well... Wish me luck haha.
Interesting. What year is your Stinger - 18 or 19? I'm up in 60060.Yeah, just learned the hard way. Here's how it went
1) Used hair dryer to head the rear badge.
2) Used plastic pry tools to get under bage
3) Badge successfully removed, residue left on car. Note, at this point there is no paint missing.
HOWEVER.
4) Removed residue with fingernails and rubbing, oddly 2-3 spots would not come off.
5) Used goo gone on spots and to clean up the rest of the adhesive area.
6) Spots revealed missing paint - would not say paint even chipped as there were no paint chips to be found, rather the paint had blended into the 3M adhesive
Mine is a ‘19. The adhesive basically pulled up the paint. A lot of people use the fishing line technique to saw through warm adhesive, but maybe that would be even worse with a Stinger.'18, in 60013. I'm wondering if it is a paint curing problem as I had freed the edges all the way around and then started the peel from the right side of the badge to the left. What really strikes me as odd is the missing paint just below the holes as this was completely covered by adhesive that was not touched by any tool.
Yep the paint under these badges is soft or not even painted....but if your new badge covers the bald spot don't sweat it....the E badge is my fav....don't forget the mono fishing line to remove badges or dental floss....those two work greatWash
RUT ROH......I already had the script badge ready to go, but it won't cover the vertical range of these spots as it barely covers the drilled holes.
