General_Vodka
1000 Posts Club!
Fuel doesn't touch the valves. Direct injectionGet a catch can and put a bottle of fuel injector cleaner in the gas tank every now and again and run a can of seafoam valve cleaner every 20k miles and you'll be fine.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Correct, that's why you do both. The seafoam valve cleaner gets sprayed in just before the throttle body, its not a fuel additive. Cleans the intake and valves. and the injector cleaner cleans the injectors since they are DIFuel doesn't touch the valves. Direct injection
I think the issue that @General_Vodka is raising is that since fuel never comes into contact with the valves, what good does adding a fuel injector cleaner do? The catch can makes sense, as does a valve cleaner. But as far as taking care of (preventing) carbon buildup on the valves themselves, what good does it do to add fuel injector cleaner to the gas?Correct, that's why you do both. The seafoam valve cleaner gets sprayed in just before the throttle body, its not a fuel additive. Cleans the intake and valves. and the injector cleaner cleans the injectors since they are DI
Sea Foam Spray | Intake Valve and Top Engine Cleaner and LubricantI think the issue that @General_Vodka is raising is that since fuel never comes into contact with the valves, what good does adding a fuel injector cleaner do? The catch can makes sense, as does a valve cleaner. But as far as taking care of (preventing) carbon buildup on the valves themselves, what good does it do to add fuel injector cleaner to the gas?
I used that stuff on my previous di car, with little to no effect. Carbon buildup on the valves is rock solid. So unless you are doing it on the weekly bases i dont see how it would help. And even after soaking it for about an hour with valves closed i still had to spend a lot of time scrubbing and picking it out. With the stinger looks like will be the same.Sea Foam Spray | Intake Valve and Top Engine Cleaner and Lubricant
This stuff. You manually spray it into the intake tube after the turbo before the throttle body, it gets sucked in with the intake air and cleans the valves. Its not a fuel additive. Thats why i specified a fuel additive for the injectors AND the valve cleaner for the valves. Two completely sperate things.
That's why you just pony up the $$$ to walnut blast periodically. From all I've read there isn't a reliable, purely chemical way to remove the deposits. Since it takes a while for the buildup to be an actual hindrance to performance, walnut blasting isn't actually that expensive to do every say 50,000 miles.I used that stuff on my previous di car, with little to no effect. Carbon buildup on the valves is rock solid. So unless you are doing it on the weekly bases i dont see how it would help. And even after soaking it for about an hour with valves closed i still had to spend a lot of time scrubbing and picking it out. With the stinger looks like will be the same.
The only reason i did it with chemicals was bacause i have no power at my condo garage. It does take longer than walnut blasting. As far as effectiveness i would not say blasting is a lot more effective, maybe 100% carbon removal vs 98% from chemicals. Will just have to learn how to remove intake manifold quickly, spend a 5-6 hours, and save 500-600$.That's why you just pony up the $$$ to walnut blast periodically. From all I've read there isn't a reliable, purely chemical way to remove the deposits. Since it takes a while for the buildup to be an actual hindrance to performance, walnut blasting isn't actually that expensive to do every say 50,000 miles.
I was suggesting people just pay to have someone do the walnut blasting, not everyone 1) wants to do everything with their cars themselves, and 2) DIY isn't always more affordable than paying someone who already has the equipment and know-how, especially if you value your time.The only reason i did it with chemicals was bacause i have no power at my condo garage. It does take longer than walnut blasting. As far as effectiveness i would not say blasting is a lot more effective, maybe 100% carbon removal vs 98% from chemicals. Will just have to learn how to remove intake manifold quickly, spend a 5-6 hours, and save 500-600$.
Hey. It is enthusiast forum. Of courseI was suggesting people just pay to have someone do the walnut blasting, not everyone 1) wants to do everything with their cars themselves, and 2) DIY isn't always more affordable than paying someone who already has the equipment and know-how, especially if you value your time.
Yes this does need done early and often but not that often. It won't remove caked on carbon but it does slow the buildup a ton.I used that stuff on my previous di car, with little to no effect. Carbon buildup on the valves is rock solid. So unless you are doing it on the weekly bases i dont see how it would help. And even after soaking it for about an hour with valves closed i still had to spend a lot of time scrubbing and picking it out. With the stinger looks like will be the same.
It's technically an owners forum, you might be surprised how many members don't spend much time under the hood of their 3 year (or less) old car.Hey. It is enthusiast forum. Of course
Everyone wants to do it themselves, even if it is not practical![]()
Hey Rafael,I use CRC intake valve and turbo cleaner right before every oil change. It’s easy to use. Follow the directions on the can. You really feel the difference after the treatment. It is crucial that you clean the valves and turbos BEFORE you change the oil, that way you you can slough off all the dirt when draining the oil.
The dealer recommends to take your Stinger every 7,500 miles in for a fuel system additive to clean your fuel system. After some research I found out they just Techron complete fuel system. Now you can buy this at any part store or Walmart for like 6 bucks. I believe the dealer charges like 60 bucks for the service. So why not just buy the bottle and pour it yourself? I found out that thy also put some valve cleaner up the air vacuum to clean the air valves since its GDI.
What are you using to clean your valves? What procedure are you doing?
Please share your experiences. Trying to save some money but I am also trying to prolong the life of my engine.
I see that this was the first crc treatment you did, how often did you do the seafoam before? About to do the crc soon myself at 11k mile, from what i've seen the chemical treatment is most effective if done earlier and more frequently as waiting until it's noticeable means there is so much build up you pretty much have to walnut blast.
From what I've seen , it does work to some extent but not for higher miles .. it needs to be done before large deposits form and done as a maintenance item every 10k miles or soI'd be interested if that stuff works because it would be much easier than taking the intake off. I think I tried something like this before I ended up cleaning my valves myself on my Optima. I used a bore scope to check the valves after each treatment and unfortunately nothing really touched the carbon buildup. I even made sure to get the engine good and hot first before treatment as that can make the carbon softer so that it can absorb more of the chemical remover.
