Just came across the most recent messages and
@westcoastGT called my name....
anyway, for all who are complaining about wind noise and dirt in the door frames, I can only recommend the rubber moldings you find on my goto website: Aliexpress.
I added rubber seals around the doors, between the doors, between the front fender and front doors, and under the doors. I did not bother taking anything apart, just added where it was logical.
Afterward, I ran water from the top or watched where water was running after a car wash and added or adjusted the molding(s) to suit.
The Z-Type molding looks in profile like a step that's been stretched, rather flat, the "D-Type" profile is like a "U" closed at the top, the flat part is the sticky side, and the "P-Profile" looks similar to a "P",
whereby the stem of the P does the wiping across the door opening on the bottom. I added cut-outs and flow-through to the P-Profile where the door drains are located. That way I could use a single piece to stick under the door.
A small bladed utility knife (1/2"?) with a fresh point did the trick. Be patient and take your time.
I did all the work during spring & summer, before any wax or oil spray hit the car, to ensure good adhesion. Use
ADHESION PROMOTER!!! if you are tackling this. Auto body supply shops sell it by the box. It's quite expensive but well worth it.
Order a bit more (like a couple of doors worth - just in case something come loose) of the moldings than you measured for or what you think you need, which will allow for screw-ups, wrong measurements and glue failure.
When it's all done, the doors close like a vault. My wife mentioned "vacuum", and it is almost like it. So far, I have not bothered with the hood or the hatch. Did not see the necessity. The car is very quiet, or a lot quieter that it was originally.
For the interested minds, a diagram and a couple of sources below, look around and you'll find a lot more. There are also rubber corner pieces available if you want to look for them...
4Meter Small P type car rubber car sound insulation seal sealing rubber strip Noise Weather Rubber 3m Sticky Tape-in Fillers, Adhesives & Sealants from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
4 Meter D Z P B Type 3M Adhesive Car Rubber Seal Sound Insulation Weatherstrip Edge Trim Noise Insulation Car Door DB 001-in Fillers, Adhesives & Sealants from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
