The car lovers social network
Automotive components
Automotive Hot or Not
Explore Pet Insurance!
Vehicle hacker protection
Advertise with us!
Timing is everything
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
The Food Order Method
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Are those carbon fiber ones??
yeasirrrrAre those carbon fiber ones??
How about some details? Where did you get them from? Which pads?yeasirrrr
How do you like them so far? What's the weight?this is the setup on alibaba from Jisu sports
That's impressive!!Them rotors are only about 11lbs a pc according to the markings. Damn that’s light!
the car accelerates SO much faster and stops and turns better tooHow do you like them so far? What's the weight?
Aight! How much for the brakes?the car accelerates SO much faster and stops and turns better too
Thanks! I will have to look into getting that.You’re missing the plastic cover that goes over the VIN markings
I am extremely hesitant to replace the bolts with a higher grade because then it will just break the diff mounting point...
Maybe the diff brace caused it, maybe if I kept the diff brace it may not have happened...
The Explorer ST (TT 3.0 with 400hp) came with either "1 bolt" or "2 bolt" diffs, and the former tend to bend/break bolts if they aren't upgraded, but a diff brace keeps it from flexing enough to break the stock bolt. My guess is during the COVID supply chain shortages they figured the weaker diff from the 2.3 models would be fine (and it probably is until you start launching or tuning).And it's one thing to have a bolt head sheer off, but to have an entire mount snap like that boggles my mind.
Are you pointing to a missing brace? Trying to learn here. Hah.
The drain hose should not certainly not have any rise! That does not sound optimalInstalled a Burger oil catch can this morning, a quick and easy job. Like the maintenance-free aspect but unsure how well it will work. The "drain" hose curls around with a slight rise going back into the engine so I'm concerned it will pool there instead of draining. Anyone with longer-term experience have any insights?View attachment 92484
