First snowfall coming tomorrow, Sunday. Car is safely in the garage.
Got out my snowblower today and tuned it up, changed the oil and stuff. Fresh gas. Started on the first pull. I am ready.
Fitted the winter wheels (now the only clean bit of the entire car until I can make time to give it a bath) and fitted new EBC Yellowstuff pads front and back after 21k miles on the originals.
Learn never to trust the stealership as well, told me the current pads were on 2mm last service and needed changing ASAP (with a ridiculous quote of over £1k), pads had at the very least double that left. Still, happy to have them fitted.
I read the stories about the factory pads and their issues, so I went EBC red shortly after I bought the car new. Swapped them out without touching the rotors. Still new.
Much better braking power, and zero pull or vibration so far.
So did I get lucky - have had my 2022 GT2 AWD for 4yrs and now has 43K miles. Brakes have been fine no issues. I use the brakes gingerly - I do use the engine for some braking and am careful on downshifts as far as RPMs are concerned. I don't deal with big city driving or hellish highway stop and go traffic. I am guessing if one is hard on the brakes and deals with rush hour traffic daily then yeah brakes wear quickly - OR - I got lucky in the crappy brake pad issue.
Nothing to the Stinger. Just added a buddy so they can talk in the driveway.
Moving forward, I will be fitting TPI and buying a Sleepytuned ECU flash and a TCU in the New Year.
So I took the car cover off popped the bonnet and decided to have a bo peep at how my valves were doing @30000 km's and with a BMS Maintenance Free Catch Can for the last 2 yr's 🤔
Turbo relocation is on the backburner for now... Maybe?
Peace ✌️
lol
Next mod - carbon fiber mirror caps to replace the OEM. Much better, IMHO. These were the actual replacement caps, not just stick on covers and the fit was pretty good, only took a little finagling and the gaps are very small and consistent. I like that there are screws on the inside to secure it on. The caps I have on my BMW 128i use just plastic clips and, at first, tended to unclip and be loose. I had to do some Dremeling and filing on both the tabs and the mounting holes to make them fit securely. One actually popped loose at the start of a track day so I ran that day with duct tape to make sure they didn't come off hammering down the straight.20251210_120927.webp
