bfglitch
From everything I've heard, you can't really go wrong with any aftermarket sway bars on the 3.3 so I have a feeling you'll be happy with the results whether you go for Whiteline, Ark, or Eibach. Eibach is the only one that include the grease fittings though.
Rears are a pain in the ass due to tight restrictions from fuel hoses. Front wasn't as bad, at least on the RWD model.
Also the brackets used for each are a bit different. Supposedly the Eibach are a little more of a pain because of how they're shaped.
That all said, I got the Ark simply because at the time they were the only one 100% in stock both front and rear. Very noticeable difference after install.
