rpoffen
1000 Posts Club!
I would say the FMIC helps a lot under certain circumstances. Last year at the track, my IAT's were pretty high leading to inconsistent results on repeated runs. They got progressively better as the evening wore on and the outside temps dropped into the '80s.Ah way up there from where I was. You put that intercooler to use I bet. Would you recommend the BMS fmic?
This year, with the FMIC, I couldn't really tell any difference in performance on repeated runs. And my times were consistent even as it got a little cooler in the evening.
The install was pretty easy too, once I figured out the silly retaining clip on the drivers side (hot) charge pipe inlet.
