Tonkabob
2500 Posts Club!
Yes. With LC or Weak Brake Snip its full throttle and i can hold it from the first to last yellow light or even up to a few seconds if needed. With Beast mode you cant really watch the lights and its real quick or its just insane spin. But i also do beast mode full throttle. First light yellow, look down and start power brake and let off as the RPM passes 2500 regardless what the tree says and hope you cut it fairly close.Ok that makes sense. So basically, even with the brake snip, you are launching the same way? Holding the brake with the gas pedal to the floor?
