Hi all,
I'm having this issue noticably at 1k miles. The most jarring is when the car is downshifting while braking or coasting. The downshifts are so hard to maintain consistent braking, I need to let off the brake entirely, then once shifted but my foot on the brake hard. Consistent braking will just jerk you around.
As an earlier poster said, "they probably calibrated it that way to use the engine as a brake and also get the car in the correct gear for that speed" and also "sometimes it even feels like the car speeds up slightly as you are trying to slow down while the transmission goes though the shift change between gears and loses the engine braking effect," both describe my issue. I'd be fine if this was sport-mode only behavior, but it's just a prevalent in comfort as well.
It sounds like their was an update to the logic that helped fix this: issue SA341. What should I request them to update? And would this had already been fixed on a early 2019 GT1 AWD Stinger? Thanks all!
The aggressive down-shifting is part of the design of a "sporty" car. Try ECO mode if you want something closer to a traditional American car automatic. Also, as is the case with a manual transmission car that the engineers were trying to mimic, you don't ride the brakes. You take your foot off the gas and let the car/engine slow you until steady application of the brakes is needed to bring the car to a halt. By the time you have let the engine braking do its job, the remainder braking phase should be firm and smooth. If your foot is usually on the gas right up until the moment you need to push the brake pedal to deal with traffic, you aren't driving in a way that the car thinks equals smooth and steady. It reads "spirited" or "aggressive" from those inputs.
The only time I have ever had the car behave as you describe, is if beforehand I have either stabbed the brakes because I wasn't paying attention to traffic closely enough and needed heavy braking, and/or combined that with stabby application of the throttle, either of which signals to the transmission to go into a slightly more aggressive mode (even in Comfort). Before getting any TSB applied, I would try to pay attention to driving and see if the car is behaving as if it had a manual transmission, or if there is something wrong.
The car never speeds up while coasting, but some people get confused because the engine will speed-up and slow-down as it down-shifts to ensure the car is in the right gear if you choose to apply throttle (something older automatics did not do well at all). The surges of braking g-force as each lower gear is engaged might fool people into thinking the car is not continuously decelerating, but it is, just at inconsistent rates--and it's the same experience in a manual transmission car or in a racing car. The goal, as it is in a race car or a manual shifter, is to use the brake pedal the least possible, but when you do use it, it's to more seriously slow the car for an upcoming corner or to come to a stop.
The Stinger (programming) does not perform well with the typical North American "race between stop lights," jerky, stop-and-start driving style. If you try forcing only smooth application of the throttle and brake, just as a test, it might be revealing. And smooth does not mean little. You can drive as aggressively and fast as you want (the car actually works better when you ask it to really go), but ensure the pedal application is smooth and deliberate, not stabby or jerky.
If you want 80% throttle, you have two choices: jab the throttle to 80% or smoothly push it to 80% taking about one second to get there (the time it takes to say "one-one thousand"). When I do the first one, the car sometimes hesitates and feels like it has major turbo lag or some other problem. What is actually happening is the jab is setting the car into emergency alert mode--it pauses to figure out how many gears to drop, curtails the engine rpm so when it figures out what gear to use it there is a proper clutch action to not damage anything, etc. Feels to us like a uncomfortable delay. If I drive the car properly (like a manual), using the accelerator position to go faster or lifting to slow the needed amount (like a mild version of an electric car) and goose the throttle using the smooth but firm method, the car responds instantaneously (even in Comfort mode).
Moving to Sport mode mostly just puts the car into the higher alert state--assuming you already know you want to be more aggressive. It's not providing any different performance. The rate of application and de-application of the pedal forces is a major input into the car's electronic wizardry (that we cannot change), so learning to work with it may be better than getting a reprogramming (that we know from experience with many other cars in the past decade can create as many new issues as it resolves). Remember, just taking your foot off the gas pedal suddenly as opposed to smoothly counts as a mild alert to the car.
Let us know if this easy-to-implement test reveals anything.
