Manual mode on GT/GT1 (with the manual shifter) is done by putting the shifter to the left into manual position. You can then shift up/down using either the
paddle shifters OR the gear shifter - similar to most older-style shiftable automatics. Very similar to my 2005 Legacy GT automatic, for example, the Q50 7-speed auto, VW DSG/Tiptronic, etc, etc.
The GT2 has a "fancy" electronic shifter that's supposed to be more like Audi/MB/whatever - I think it's crap, and it has caused a few accidental shifts into reverse or neutral as well. This is one reason I specifically got the GT1 instead of the GT2 - more control over shifting when driving hard.
I think the GENERAL behavior is:
-use the
paddles from "auto" mode to start manual mode. If you hold the up paddle for 3+ seconds, it will take you back to auto mode ("D").
-if you stop driving aggressively in paddle-started manual mode for 30+ seconds (or come to a stop or maybe < 4 mph or something) it will go back to "D"
With GT/GT:
-if you put the shifter into manual mode (will have to test again), by default, it stays in manual mode, but will upshift at red-line and downshift if coming to a stop. Also maybe if rpm get too low. However, should still stay in manual mode in general (i.e. will only upshift one gear at a time, no fuel economy shifting, etc)
-if you put shifter into manual mode and disable nannies, will get full bounce-off-red-line behavior
-not sure what happens if you are in manual mode with nannies on - may depend on paddle usage or not. Need to verify.
At least, that's my current mental model - there are some unverified modes.
