Johnnyfive
I have a chip in the trim on the lower grill and the material shows as white. Do we think the grill and trim are the same material?
You could very well be right. One of the disadvantage of aluminum over another metal is it is non-metallic. If it was a real metal and was metallic, this could easily be confirmed with a magnet. I used a magnet to see if our hoods are aluminum or steel, which I confirmed to be steel.
I'm actually surprised if Kia used a real metal on this trim. Considering how convincing artificial materials can look, I'm a bit surprised when they spring the extra cost to give us the real thing.
As a counter to your notion, I wonder about the black chrome accents in the bumper. On my lower grille, I've found a bubble in the material, leading me to believe it is a fake overlay like fake chrome grilles. There is no way this would happen on a true metal surface. Also, there are those here who have found chips down to plastic (it appears) on the front black chrome as well.
There are only the 6 window trim pieces that I am aware of that are aluminum. The mirror housings, grill accents, and other black chrome pieces are likely ABS plastic covered with a shiny substance (chrome plating, vacuum metalizing, spray chrome, who knows).You could very well be right. One of the disadvantage of aluminum over another metal is it is non-metallic. If it was a real metal and was metallic, this could easily be confirmed with a magnet. I used a magnet to see if our hoods are aluminum or steel, which I confirmed to be steel.
All the black chrome (mirrored finish) trim is hard plastic (probably acrylonitrile butadiene styrene, abbreviated ABS). Window trim (b4 and after pics in posts 90 and 94) appear to be anodized aluminum. You would therefore have a chip through the black chrome finish in the grill exposing the white colored ABS plastic.I have a chip in the trim on the lower grill and the material shows as white. Do we think the grill and trim are the same material?
The colors are fairly similar but the surfaces are very different. The polished aluminum has a satin or semi-gloss appearance whereas the black chrome is mirror-like. About the same as the difference between chrome plated and polished aluminum wheels. But yes, probably requires two different approaches to detailing.The annoying thing is that means two similar looking materials need two different types of maintenance.
Aluminium is absolutely metallic, because it is a metal.
The magnet test only works to identify ferrous (iron-based) metals, and even then not all of them - many stainless steel compounds are not magnetic, but are definitely based on iron.
I think he inadvertently stated "non-metallic" when he meant to say "non-magnetic".
That was a typo on my part and was meant to be "magnetic" rather than metallic.
I have plenty of experience with this in our -40C winters...ask me how I know a plastic shift knob is a lot warmer than a metal one in winter. ;D
Another consideration with anodized aluminum trim is that it by definition is anodic - it's a sacrificial metal and is reacting with its environment all the while giving up electrons resulting in the visible surface oxidation, similar to using zinc, magnesium, or aluminum anodes on a boat to protect the drive unit and other metal parts from constant exposure to water. Left unprotected, the trim will continuously react resulting in a quick return to a spotty, grimy look. When I first posted in this thread I mentioned that I suspected water droplets from condensation as being an accelerator of the effect. This makes sense because the anodic reaction will take place at a much quicker rate in wet/high humidity conditions. If you wake up most mornings and there is condensation on your car expect to see faster rates of oxidation. If you live in a desert, have a garage, or otherwise dry environment you probably won't experience much in the way of oxidation.
Maybe @MerlintheMad could do an experiment for us since Yootaw is mostly desert? If he could drive his Stinger 20 miles from his home to the northwest (315 deg), park it overnight, and then report back to us on any degradation to the trim.All very likely. My car is only outside at work for a normal workday and is otherwise garaged. Our resident with the most perfect Stinger, @MerlintheMad, also noted his trim is in good condition. He also states he washes his car a few times a week, so this water condensation adding to oxidation is washed away by his cleaning efforts. My trim is pretty good with only a hint of this defect, my garaging may be slowing this effect. I admittedly haven't washed the car as much as I normally would like, because IT WON'T STOP RAINING.
I'm in Utah, and my trim is messed up like this after I started parking outside every day (Moved, no garage.)
I've got an uneducated hunch that it's accelerated by wiper fluid though. The windshield wiper fluid runs down the trim like a river when at speed. My trim is still nearly perfect right in front of the mirror housing, which is where wiper fluid never reaches.
Who knows though! I'm taking my car in to get detailed on Friday, and I'll ask the guy to put some elbow grease into those pieces.
Edit: mine. Shiny spot is where I managed to clean it, but didn't want to go too ham on it in case I cut through the paint or clearcoat or whatever.
