People who have an overwhelming need "to be right", more often than not have fragile egos.
@itguy61, it would be best if you would realize there is more than one correct answer to solving this problem.
Three solutions are proven successful in remediating uneven rotor surfaces: higher quality rotors, different pad compounds, or a combination or both new pads and new rotors.
The pads are Brembo pads. There is no way the quality is sub par. The rotors are not Brembo. Kia cut a corner here. The stock rotors are as cheaply made as possible. Actual dealer cost, not the price they show you as their cost which includes an overhead factor, is less than $50.00 each.
While new pads is your ideal solution, that does not make it the best solution or the only solution: just your preferred solution. Let it go
