itguy61
It’s the cheap ass rotors. These cars are to heavy for these rotors.Burned my rotors and pads to nothing by 11000 miles. Got all new rotors and pads all the way around last week. Even the kia tech told me to switch to after market rotors when these take a crap.also changed brake fluid to 100% synthetic Castrol fluid higher boiling point helps with brake fade and cooling.
What does burned your rotors mean? If you mean vibration then it was probably brake pad deposits on the rotors. I have stock rotors on aftermarket pads and no issues at 6000 miles on them.
Did you go with the "curved slots & double drilled" option on Khartunerz? Any reason that you chose these over the dimpled/slotted choices? Have you posted any pics of your setup? If yes, I will search and find. How are you on brake dusting with the new setup?
. Going aftermarket all the way, not taking chances with OEM rotors and supplied pads; OEM parts ain't exactly cheap to experiment with. I just wish someone would make or cross reference a rear pad already -_-'
