Manaz
1000 Posts Club!
I have experienced several "iterations" for various periods of time.
1) Stock rotors and stock pads for 7k miles.
2) Turned rotors and stock pads for 1k miles.
3) New OEM rotors and aftermarket pads for 2k miles.
4) Turned rotors and aftermarket pads for 2k miles (current configuration).
In normal city driving, to and from work, I thought the issue was getting (got) better. I just returned from a trip to the NC mountains and was going back and forth with a Land Rover Sport SVR through some mountain roads for about 45 minutes and was really disappointed in the brakes. They were very noisy. Not squeeky noisy, but just a lot of scraping/friction sounds (windows up) and then after about 30 minutes, the "thump thump thump" sound (that correlated with speed) when the brake pedal was pushed. I never had a lot of confidence in these brakes and this solidified my opinions. I guess it was brake fading, there were times where I just kept pushing the pedal without a real increase in stopping power, pushing all the way only triggered ABS once.Apparently, they were hot, but as I have said many times before, I have pushed 3800lb-4000lb cars this hard before in similar situations and never had the brakes let me down. It really affected the way I was driving and I had to leave myself a lot of room as a precaution. Still beat the Rover to the top though!
Not sure what is next. I can't justify pumping a lot of money into a car I am leasing for aftermarket rotors and pads on my dime, but I want to enjoy it while I have it. That is my dilemma now.
That sounds like a combination of issues. Not fun.
You mentioned not getting good brake pressure when the brakes were hot. This can be pads reaching their thermal limits (the pedal should feel roughly the same though) And the brake compound and binding starting to fail, or fluid boiling (pedal travel will generally be longer and "squidgier").
The former can absolutely result in masses of pad material deposited on the rotors, and given what you described regarding grinding noises and the vibrations you ended up getting, that is where I suspect you ended up. You may have had some fluid issues too - if you've had your fluid in the car for a while it may have absorbed sufficient water to have "gone off" - irrespective, after this event I'd recommend a flush with good DOT4 OR DOT5.1 fluid, because booked fluid is compromised in its ability to operate.
