Kinvara8017
We now have a fast heavy weight GT2 AWD JB4 car to add to the mix. But i'm afraid it helps debunk the rest of @StungBlueGT2 's bench racing tuning theories. We have established that stock boost even as measured by JB4 can go up to 14.5 PSI, and even 16 PSI in extreme conditions as measured by boost gauge. 14.5 PSI +8 on WMI = 22.5 potential, so same boost, could go higher.
The new heavy weight challenger has more mods, similar traps and .1 slower ETs so far. Extra mods are WMI, throttle body, BOV, no mufflers, no secondary cats. (my secondary's are back on and my muffler is not straight through) The WMI FMIC combo seems to work as he said he was hitting 80-85 IATs to my 119 IATs at my last outing when I ran a 11.89, 11.90 @ 117 MPH. He also is doing some trick to launch on boost so no launch advantage now. I'm still resistant to WMI but just the lower temps with no tune or octane changes should get me down around 11.75 or lower.
1. 11.86 @ 117.16, @Tonkabob, 7.67 @ 93.53, 1.84
GT2 AWD, Tork ECU tune, Ark catback, JT intake, UP FMIC, SSR midpipe (11.89 w stock MP), E15
3. 11.959 @ 117.80 @Kinvara8017, 7.75 @ 93.28, 1.838
GT2 AWD JB4, WMI, UP FMIC, throttle body, VT snorkel, BOV, Custom primary cat back straight pipe exhaust
I dont do passes on WMI, its actually not as fast and i cant get higher boost at lower rpm ATM... I will use it for a cooldown WOT lap between map 5 pulls.. Ill sit at around 105-110 (if i remember correctly) at the end of a map 5 pull, 135 by the time i line up again, then drops it to 80ish after a meth pull. Ill pull off and shut down the car while waiting in line, then line up with a 90degree IAT for a good 5 pull... I gotta get burger to turn up the low end boost for my map 8 for me as thats what i thought WMI would do... but i make do with what works
