westcoastGT
5000 Posts Club!
Not really , I did read that one our Aussie friends filled the holes with silicone first , just be carefull and you'll make it . Worste case , take it to an autobody shop to do for you , the Stinger badge is actually in 2 pieces but joined by the double sided tape . I made a level template by taping a strip of masking tape parallel to the trunk lip , it made eyeballing the application much easier ................good luck ! .................are you putting the E badge on the front , If so you need to remove one position lug from it to fit properly , side cutters or a dremel will do itAre there any alternatives?
