StungBlueGT2
Sustaining Member
So you put 255’s on 8” front tires? If so did the installer mention any safety concerns with 30mm oversized tires on stock rims?Good Morning I have had my Stinger for 6 months now with 30000 km. Just replace the worn out michelin's with 255 35 19 General's all 4 corners on stock rims. Looks a lot better and no clearance issues with the front struts.
I know 255s are recommended for 8.5”, but tons of people put oversized tires(including +30mm above) on stock rims without issues. So how much extra is still considered safe? 10mm? 20mm? 30mm?Do not put 275mm wide tires on a 8.5" wheel. the max recommended tire width for 8.5 is 255mm. A 275mm tire is NOT SAFE on a 8.5" wheel.
Also, my example is only related to rear tires so they won’t be tasked with the lateral handling, just straight line launch traction.
