I'm curious how much weight can be removed from our cars with the easier stuff, seats, mats, spare, etc.
Anyone with access to a scale want to help us out?![]()
Good info! I guess the covers are that heavy to dampen the road noise. Surprised the rear seat are that light. I wonder how much the front passenger seat weighs.Just weighed some stuff this morning. Races aren't until Sunday but I got bored.
100lbs so far. That gets a GT1 or GT2 down to about a GT weight.
- Spare tire and accessories 55lbs. (40 for the spare and jack, 15 for the 2 covers and deck lid) Spare slightly lighter than I expected and the covers heavier than I expected.
- Rear seat backs 45 lbs. (15 for the small and 30 for the large side).
I didn't pull the rear bench yet but its only about 10 lbs max.
Remote control / driverless car mod? lol100# down, 200# to go.![]()
Tonkabob just wondering how the stage 2 looked on the Dyno and if you got it on the Dyno for a runTransfer station. I just had a few florescent light bulbs so a free weigh in. I'd be curious to see what the difference is between GT1 and GT2.
Haven't been on the dyno yet but hit the track this week and ran an 11.89 with just the tune, intake, fmic and catback.Tonkabob just wondering how the stage 2 looked on the Dyno and if you got it on the Dyno for a runas I am thinking of either stage 1 or stage 2 when released he he
Darn it that works great just curious on how it runs on 93 pump fuel as my car is my DDHaven't been on the dyno yet but hit the track this week and ran an 11.89 with just the tune, intake, fmic and catback.
I have 92 here in Wa. Stage 1 is 18 psi and works on 92 octane. Stage 2 is still in testing and mine is currently at 22.5 psi which works on E15 (4:1 92 pure gas and e85). Or 92 and some octane booster works. Not sure what he'll settle on for stage 2 but I'm sure you can request a 93 octane tune maybe 19 or 19.5 psi.
I have no idea. Its a big AWD GT2 and best track is 11.86. It does launch better than most, often hitting 1.83 60 foots. Highest track trap I've seen 118 and cool no heat soak dragy trap of 120 mph. The hottest piggy back tunes are also in the 21-22 psi range so i suspect the hp is about the same, 450 ish whp.with 22.5 psi do you expect over 550 whp?
My piggy back most likely hits 17 to 18 psi as I only got 356 at the wheels and torque run around 500 lbs running of 94 Chevron with some octane boostI have no idea. Its a big AWD GT2 and best track is 11.86. It does launch better than most, often hitting 1.83 60 foots. Highest track trap I've seen 118 and cool no heat soak dragy trap of 120 mph. The hottest piggy back tunes are also in the 21-22 psi range so i suspect the hp is about the same, 450 ish whp.
A friend of mine is running 23psi on the stock turbos and his car does 570whp on the dyno.I have no idea. Its a big AWD GT2 and best track is 11.86. It does launch better than most, often hitting 1.83 60 foots. Highest track trap I've seen 118 and cool no heat soak dragy trap of 120 mph. The hottest piggy back tunes are also in the 21-22 psi range so i suspect the hp is about the same, 450 ish whp.
Wow 570 whp , 23 psi boost that is a lot of pressure if those turbos only handle 25 psi Max I wonder then what his torque values are , please ask him if possibleA friend of mine is running 23psi on the stock turbos and his car does 570whp on the dyno.
