SRV
Sustaining Member
- Nov 20, 2021
The consistency is the important part.178 psi min. Didn’t quite Reach that but numbers are consistent
Your lower readings could simply be from the compression guage itself reading lower than it should.
Or, it could be from the cam-timing holding the intake valves open longer on the compression stroke (..retarded timing), thus bleeding and lowering the dynamic compression ratio. So the cams may not be timed correctly, or something might be wrong with the variable valve timing mechanism - but I would say that's unlikely unless someone was in there.
