ZyroXZ2
- May 26, 2018
Welp, it looks like @Stormlasher is correct: I tested 80% methanol per LAP3's official recommendation, and while the midrange pull is the same, the pull above 5K RPM is harder. Of course, someone might say, "if they programmed for 80% methanol, that's what you have to run", but I had hoped they programmed for 50/50 and were just recommending 80% to play it "safe".
Sadly, I have my disagreements with this much methanol ratio in terms of safety (many of you know, all it takes is for things to go wrong just once), and the lifespan of components facing a higher concentration of spray over the years, but it definitely performs better. It also confirms my suspicion that LAP3 is more focused on using WMI as supplemental fuel than cooling/octane boosting. Water itself is the ultimate cooling and octane boosting factor, methanol is really just there to manage combustibility of the mixture. The only reason one would tune for 80% methanol is because more fuel is needed in the combustion chamber. This would inadvertently confirm other vendors stating the stock fueling system can't keep up.
Having said that, I will be finalizing my review soon as I've gone nearly 1000 miles on the WMI system, now.
EDIT: Meant 5K RPMs, ughhh, I think typos get worse with age...
