Rokblokz Tire Splash Guards
Got the Slimz in black
Sorry - a couple of really dumb questions.
the spacers - in front of behind the liners? I think the instructions are saying in front...but does it matter?
the metal mounting clips, does the flat side go facing the felt? Reason I ask is...
Has anyone run into any issues with the fronts, “mounting hole A” (the one that’s in the middle, not fully tightening? It’s almost like the screw is stripped, but trying another screw doesn’t really seem to matter. I can tighten it, but, it won’t fully secure before it goes loose again. I’m sure they don’t need to be cranked down on but I also don’t want it to work it’s way out.
from what I can tell in the poor quality instruction photos, the flat side of the clip faces you/the felt, but that also means where the screw threads meets the clip is further away. Plus, hole “B” (the very top, with the larger spacer) screws in just fine.
Am I missing something here?
I had to re-do my rear rokblokz to fit a rear diffuser and ran into your first issue of not fully securing. I tried many times with an angled screwdriver thinking I had screwed it at an angle. So I took my wheel off and tried using a power tool. Still didn't work.
Gave up and just didn't use those spacers and finally worked; made me think that the spacer was too big, preventing the screw to actually...screw lol. But I mean, I was able to fit all the other spacers, so I'm not sure what's going on.
I have also only put the spacers between the flaps and liner.
Thanks dude. I'm thinking of grabbing some smaller spacers over at Home Depot and giving that a go.
LMK if you find one!
Maybe alternatively you can cut off a few mm at a time to see if that works.
Anyone replace OEM with these? Eying the Slimz as the coverage seems to be slightly better.
I have them and looks good.
Slims have fantastic coverage. I'm on Eibach lowering springs, and did not have enough room to install them without removing each wheel. They're a bit pricey in my opinion, but so far they are worth it.
I never had the OEM, but wanted coverage. Did some research and ordered the slims and they are great.
Were you guys able to fit side splitters/skirts with the Rokblokz? I'm eying the M&S Force side splitter and it looks like it might interfere with the front one fitting.
The M&S v1 side splitter looks like it may allow fitment.
Thread revival haha. Damn these look awesome. It's a shame that with shipping it ends up costing $300 NZD mudguards which is nuts... Anyone happen to have their OEM mud guards for sale? Can't buy them in NZ anymore
My car with Red Slim mud flaps
