These look pretty cool and looks to be compatible with after market side skirts. Had to remove my oem mud guards in order to install side skirts. Curious if anyone has installed these that have side skirts.
Nice! wanna see this. don't forget the picsHope to install my maxton side skirts this weekend.
Making me regret getting black/black instead of red/white. Amazing look!Just installed my Rokblokz for anyone interested in seeing what they look like with side skirts - have the M&S.
I have a 2018 Stinger so I didn't need the new additional clips as there was already a screw thread for the bottom hole.
View attachment 48895View attachment 48896View attachment 48897View attachment 48898
Agreed, as cool as it'd be, it'd also be dirty 10 seconds into driving post wash, ha! I do really like the black/black look as it meshes with the other black elements well.I had to google that colour combo on white cars to see how it would look before making a decision. The other choice was white/black, but white would get dirty very quick.
The red lugnuts are a nice touch.I had to google that colour combo on white cars to see how it would look before making a decision. The other choice was white/black, but white would get dirty very quick.
Hi ... Firstly, this is a SPECTACULAR IDEA!!! The TEMPLATE was great ... I presume that it prints on a standard US 8x11 paper?Here's the template
I used a Toris SS304 stainless steel mesh I found on Amazon. Worked perfectly.Hi ... Firstly, this is a SPECTACULAR IDEA!!! The TEMPLATE was great ... I presume that it prints on a standard US 8x11 paper?
Your photo looks like you used perforated steel plate and not a woven stainless steel mesh. I think that the mesh is a nice alternative. What size of mesh did you use? And how much (sq inches) was needed? The mesh size defines the wire diameter: Mesh size 1 = 2mm thick wire and nearly a one inch opening (obviously too large!) and Mesh size 400 has a 0.018mm wire with 0.0455mm (0.018inch) square opening ... obviously too small.
In you experience, (1) what mesh size did you use; and (2) ARE YOU HAPPY with the results?! For me HAPPINESS is (1) the paint isn't marred by debris flying through the vent; (2) the mesh maintained its integrity (no holes punctures. Lastly, how much mesh (sq in) did you need to use?
Thank you in advance for your reply. ---I'm new to these boards ,so send "PM" (personal message) doesn't appear available to me.
Thank you.I used a Toris SS304 stainless steel mesh I found on Amazon. Worked perfectly.
Sorry to drag up an old post, but how far out does the edge of the flaps poke from the face of the wheel? Tossing up between slimz and Original but not sure how far past the wheel face they sit.Just want to add, bought the Rokblokz originals 2 weeks ago and installed last night. Went without a hitch and they included all hardware needed (including the 2 nylon screw clips for the front bottom hole). Great quality and I love the extra coverage they provide over OEM Kia ones.
So... I just installed mine. But I can't seem to understand how there's leeway since you just screw into the 2 or 3 holes. Unless if you're referring to the fact that the holes are wider than the provided screws?I intentionally put mine further out for extra protection, especially on the rear. You have some leeway on where they're placed.
View attachment 51783View attachment 51784
Basically, mine had a bit of room to position them as I recall. But if wanted perfectly flush you'd probably need to make your own holes.
