Question for the wheel experts here
@GetYourWheels would 20x8.5 or 19x8.5 offset 32 / 35 be a flush setup? Not looking to have wheels / tires extend past the fender. Probably 245 tires.
Im not a professional racer but do race. Often cars setup with stagger where designed that way and dont work well with square setup unless you do a lot of suspension tuning. Goes beyond looks often. Can say my 370 S and my Cayman S worked best with small stagger. My car with OEM 225 does incredible job turning and car has tendency to power oversteer - I was thinking 265 rear 245 front would be nice with 8.5 front and 9.5 rear. However like simplicity of just putting 9.5 up front with 255 and running square. Just worried that might make car into darty over steering monster on the street but hey I could handle it just worried about my wife at the wheel. Like the looks of square setup for sure.
@GetYourWheels looking to get some aftermarket wheels. I'm lowered on eibach springs. looking to go 19x8.5 with the stock tires up front and 19x9.5 with the stock tires in the rear. What would be the best offset for that fitment ?
No issues with that setup.
19X8.5 +30 and 19X9.5 +35 would get you pretty flushed with the fender on stock tires.
I finally have a question. I have a GT2 with offset 19's. I need a second set of wheels for winter tires. Will the OEM 18's fit?
Yes of course, GT's can come with the 18s as well.
I really would like 19x9.5 square.... I see that the ark 270 wheels at 25 offset were capable without modification. Are there any other wheels and offsets you guys know ? Would +22 work ? +20 ?
The +25 is already a pretty aggressive offset and stuck out a bit, lower offsets like +22 or 20 will push the wheels out more. They'd clear the suspension and brake component, but they would stick out more, so its up to you if you would want something to fit that far out. Hope this helps!
I loved the look of the ark on +25 so I don't mind it they poke out a bit. I only used +22 because I saw a wheel that had that as an option. can the stance sf07 run 9.5 square?
I like how the arks stuck out a little so I don’t mind. Is it possible to run the stance sf07 at 9.5 in the front with no modifications?
It is possible to order the SF07s in the 19x9.5 +20 to 25 offsets, they'll fit similarly to the Ark set so stretched tires would be needed as well
They're running a 245/35/19 tire to get enough stretch to fit the aggressive fitment without rubbing, a 255 wouldnt really stretch on a 9.5 so it may not be enough to fit that setup without rubbing
sorry I'm a noob when it comes to this stuff. so you can't run 255 all around ? you need 245 all around ?
