Some dealers are replacing rotors, some are machining rotors & some also pads.Is Kia AU doing anything about the infamous brake vibration?
Stinger was purchased with only 23km on the odometer in May 2019.Some dealers are replacing rotors, some are machining rotors & some also pads.
it’s the pads that are causing the issue, by changing the same OE items with the same it is only a bandaid & the problem will more that likely retur, it’s a dog chasing its tail.
I’m now running dba slotted rotors & pads since January 2020 without issue.
The OE pads leave material on the rotors & it builds up & causes the shudder.Stinger was purchased with only 23km on the odometer in May 2019.
And I'm very gentle on the brakes. Not sure why it shudders when braking. It's been this way for the most part.
How do the dba pads perform compared to oem?
Your issue seems to me to be the material the rotors are made of, the pads grab then slip at a very high velocity which transfer up the steering wheel as a vibration, the rust you speak of and the good brakes are the pads biting and not slipping for the first few brake applications, then once you wear off the rust, the problem returns..................I would get some aftermarket rotors and pads and I bet your problem goes away.....................KIA have put cheap rotors on all these vehicles I would guess and the rotors are SHI*Mine is going into the dealer next week for a "detailed inspection", as I have complained many times to the dealer and now recently to Kia. Have been previously told no major fault found, although the dealer did say I have a minor warp in a rotor, and I would have to pay $390 to be machined. I have felt this since 3,000km and am now up to 24,000km.
I am not convinced it is the rotor though, as it comes and goes and can vary between a minor/major rattle felt and seen in the steering wheel.
It is definitely worse when the brakes are hot, but I am not abusing the brakes at all... both Kia and the dealer did suggest I was driving aggressively, which is absolutely not the case. I did then ask if the brakes have to be replaced every time they lend a vehicle to a motoring journalist, and they said "no" - well, it's not through brake abuse then is it!! haha
Also, a major clue... I hand wash the car once a week (maybe more!) - and am using garden house as you would expect.
After every wash the brakes feel great - and for the first few applications there is a little noise and grinding going on, which is surely some minor rust or whatever left over from the washing... but the brakes then feel great, NO STEERING RATTLE!. A day later, then I get the steering rattle again - so surely this is to do with pad build up, and has nothing to do with a warped rotor?
This is the only fault on such an amazing car!
My Kia had done about 30,000ks it was sent to warranty. So make sure they measure the thickness of the rotor and pads.Mine is going into the dealer next week for a "detailed inspection", as I have complained many times to the dealer and now recently to Kia. Have been previously told no major fault found, although the dealer did say I have a minor warp in a rotor, and I would have to pay $390 to be machined. I have felt this since 3,000km and am now up to 24,000km.
Aren’t they Brembos. Not sure they are cheap.Your issue seems to me to be the material the rotors are made of, the pads grab then slip at a very high velocity which transfer up the steering wheel as a vibration, the rust you speak of and the good brakes are the pads biting and not slipping for the first few brake applications, then once you wear off the rust, the problem returns..................I would get some aftermarket rotors and pads and I bet your problem goes away.....................KIA have put cheap rotors on all these vehicles I would guess and the rotors are SHI*
What's this "mounts" issue all about....first I've heard of pad deposits being described that way.OK, great update for my issue. I called Kia and they arranged for my dealer to do a thorough inspection of the brakes - and when I collected the car at the end of the day, it had been fitted with new rotors under warranty.
Previously the dealer said there was no issue at 3,000 and 10,000km (when there clearly was) and at 20,000km they then agreed their was a minor warp in the rotor and I would have to pay $390 to have them machined.
Today they instead said that were was indeed a significant warp - and Kia agreed to replace under warranty.
Thank you Kia!
Whereas previously the dealer had checked and confirmed that my vehicle had not been fitted with the known problem wheel "mounts" which were known to cause a warp in the rotor on earlier models, but today they said that actually my vehicle DID have the known disk warp issue.
It is not clear if they have just replaced the disks or if they have also resolved the issue where the wheel mounts cause the rotor warp to occur, I will see what I can found out.
I can say that it is really amazing the drive the vehicle with smooth brakes once again!
Incidentally, my vehicle is known as a MY20 (so I have a heated steering wheel), but was lovingly assembled in Sept 2019.
This is exactly how i'd describe it. Vibrations occur when driving sedatly and applying brakes from speeds of about 70-80kph.My GT is about to have it's 20,000km service at John McGrath KIA in Woden (Canberra).
Since 5,000km I have been getting a steering wheel shudder under braking - and at the 10,000km service they assured me that nothing was wrong, which was mighty frustrating.
I am going to tell them the same as before, that I am getting a shudder under braking -- but it comes and goes and varies in intensity. It seems to be worse when the brakes are warm, and to not do it when cold - but it doesn't do it all the time when hot - and I am not really ever doing any massive stops and am driving far more sensibly than a Stinger deserves too! Actually, I think it gets worse when driving around town slowly with the family in the car, and it may not be as bad when I drive with more spirit on my own - but I am still driving sensibly.
I can not see or feel any marks on the rotor itself... this is the only fault with such an awesome weapon of a vehicle!
Did you have your discs machined when you replaced the pads?I replaced the front pads with DBA street performance and they were good for a couple of months. But the steering shuddering back. Maybe the XP pads are better?
Just a FYI that my brake shudder problem didn't return.
I have now done 56,000km, with 35,000km clocked up since Kia had the dealer replace my rotors back in May 2021, and the issue didn't return - which was both a surprise and relief.
