Volfy
1000 Posts Club!
FWIW, the bleed order specified in the service manual just allows you to flush the entire system fastest with the least amount of replacement brake fluid. The first time I bled the Brembos, I just followed the old convention of starting from the farthest corner, the diagonal, then the other diagonal. Works just fine, but I did use up more than 45 Oz. I probably overdid it too at some nipples, stayed on it for good while after the clean fluid has already passed through. It just took a bit of extra time and fluid.
