AV8R
5000 Posts Club!
- Dec 13, 2017
- Location
- Perth, Western Australia
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
I first noticed a slight whinnying sound from the rear-end when turning while reversing and making u-turns. My old Trans-Am had PosiTrac(same as Limited Slip Differential) and used to make similar sounds so I didn’t think it was a problem. However the sound suddenly got worse and this week I felt & heard a “clunk” while reversing & turning out of a parking spot. I immediately called my Kia tech and he told me to come in. Last symptom was on the way to the dealership while merging onto the highway. As I accelerated onto a wide sweeping on ramp the car suddenly pushed harder to the left, but corrected when I let off the gas. As soon as I gave it throttle it pushed left again like it had AWD understeer. Only other way to describe it was that it was giving more power to the back right wheel on throttle.
It actually scared me and glad I was able to make it to the dealership before I had a similar problem as the OP.
I’m not trying to alarm anyone and reiterate that it’s a very very rare issue. I do absolutely love my Stinger, but this isn’t something to take lightly and again suggest contacting Kia if any similar symptoms arise.
Just passed 5k miles recently.How many miles you had in yours?
Got mine February 2018 and think it was a December 2017 build, but will have to double check when I get it back to be sure.Hey guys (Jim and SBGT) - what are your build dates?
Different markets (US and AUS) has me a little concerned, but if the build dates are close, that might mean something.
GT2 with LSD.Were these mechanical LSD (Limited Slip Differential) cars or the standard differential?
GT2 with LSD (Limited Slip Differential).
Hope that helps and hope Jim responds soon too.
My best and worst from Friday night. Wasn't ready for the light on the first run and still trying to figure out what happened on the second run. I think it dumped boost.(And yes, it was in Launch Control mode). I think a 12.5 is very respectable but I think it could be faster. I spun too much on launch.
This is somewhat confusing. Was this in a Stinger or another vehicle? And typically it's not the quick lubes responsibility to check the transfer case for lube. That's like a 60,000 mile changeout for most manufacturers.No LSD (Limited Slip Differential) on the AWD, although it is now standard on all GT's (was not in 2018)..
I had the transfer case between front and rear lock up at around 90 on the highway coming back from SC late one night. All four wheels locked. THAT was surprising. After a few seconds, there was a loud bang, and I had steering but no drive. Managed to dodge across 5 or 6 lanes to the shoulder, and coast to a stop just short of an exit ramp. No cell phones back then (early 90's).
Dealer was able to get it changed under warranty, but the real cause was the quicklube places I had been depending on for regular service and inspection had never even looked at the transfer case. It was dry, and VERY blued when they cracked it open..
My tech said they tried flushing & refilling the differential with “lube” first, but it didn’t eliminate the problem so it had to be completely replaced.Mine is waiting on a model-specific differential lube. The dealer installed the differential but nobody ordered the lube which is apparently special for the Stinger only. They thought that the diff would come filled as does other components. Wonder if this lube is an attempt to band aid the problem verses a total recall. I have found 8-9 similar failures online now. Has anyone read anything on this lube situation?
I spoke to my Dealer Service Dept. last week about this, said they would be changing the diff oil out if customers complained about any noise, they were ordering stock in & would call me when it arrives to change out as a precaution.
