Mr Skillet
- Jun 26, 2018
Spoke with eibach internal R&D, spring rates are an even 15% increase over stock front and rear, swaybars however are actuallt about 70-100% stiffer rate wise over stock depending on which position you use. Sounds like the resulting immediate turn in and rear control is the end result. I'm ordering a set, can't wait to get it installed and try it in the dry hot weather here.
