Bamm1
Founding Member
- Jan 31, 2017
- 50 percent of engine torque can be sent to the front axle via a mechanical clutch in the transfer case (torque is not split side to side.)
- In normal driving situations, Stinger’s default Comfort mode sends up to 40 percent of engine torque to the front wheels.
- In Sport mode 20 percent more is sent to the rear to make the Stinger behave more like a rear-wheel-drive vehicle.
- Sport mode—yaw sensors allow for a greater degree of slip angle before engine output is cut and ABS actuators are engaged.
- GT comes equipped with a mechanical-type limited-slip differential (LSD) with a carbon friction disc.
- TCS and ESC systems; unlike most vehicles in HMG, Stinger will come to market with a two-stage system similar to those seen on high-end German sport sedan rivals. At the push and hold of a button, ESC and TCS can be fully shut off, leaving only ABS to help stop shenanigans.
reference: http://www.motortrend.com/cars/kia/stinger/2018/2018-kia-stinger-gt-winter-drive/
