Issues after having front differential replaced
D
D1ST0RTION
Good afternoon everyone. I have a 2022 Gt2 with 18k miles that got fully bottomed out because of the lane missing due to unmarked road construction which caused the front differential and some other parts to need to be replaced. After having all the repairs done and an alignment done, whenever I accelerate more than 25% of the gas pedal the car seems to want to pull from the front left section or push from the right rear section. The way to describe it is as if the power distribution is off and certain wheels have more power than others. I live in Alaska and this worsens whenever it touches any bit of snow or ice. The second it does touch something that disturbs its traction, it acts as if it would do a 90 degree turn to the left if I didn't stop accelerating. It also still pulls pretty good to the left and sometimes to the right. I had the shop that did the work check the alignment and it supposedly checked out and had rear suspension parts replaced because they said that could be the issue but it is still happening. Any feedback is greatly appreciated and thank you for taking the time to read this.
I'll say a few things. First off, I find it off-putting to respond to what looks like a driveby or "guest" post. It looks like you don't want anyone to know anything about you.
Second, to address your problem, have you tried accelerating with traction and stability turned OFF? And if so, does that change the feel you describe at all?
When you say "bottomed out", how much undercarriage and suspension damage was inflicted? In other words, did the bottoming out bring the car to a stop, like high-centering? If the bottom was impacted and then dragged enough to damage the front AWD system it sounds to me like a lot more than a differential was affected.
I don't see how you can replace a few suspension parts and expect that "shotgun" approach to score a remedy. I think that this is going to take a full-blown inspection nose to tail and vice versa with the car in the air or over a pit, with mechanics who know their stuff thoroughly. In other words, not KIA.
Do you know how to use paragraphs?
I'm not reading that mess.
