Windows going down instead of up
dban
Romania
The window on the driver side started doing this almost one year ago, so I went to the dealer and they replaced the whole window lift assembly except the motor. The problem was still there, so they replaced the rubber channel, which still didn't fix the issue. They are now thinking to replace the motor...
A couple of weeks ago the same problem started on the passenger side and today all windows present the same issue.
The problem is not related to the window button/command, it happens also when using the key fob.
Is this happening to anyone else? Any idea what the problem is and how to fix it?
Thanks!
Can't say I've experienced it or seen it discussed, so not much help from me. But the key fob window control was new to me...any idea which years/models/regions got this feature?
Thanks!
I guess this would convince the dealer to NOT replace the motor, since this is apparently an issue with the module that controls the windows. I hope you sort this out. And also, this is a first for me too. I've never read on here in over seven years of any window issues.
Mine is Europe 2021, I don't know about the US models. Did you try keeping the lock/unlock buttons pressed for more than a couple of seconds?
I tried each by itself. Does it need to be a certain combo, like having the car locked first, etc? Or is it just hold unlock for windows down / lock for windows up?
It only works with engine off...
No luck. Held lock for 10 seconds, unlock for 10 seconds, starting from both a locked and unlocked condition, close enough for the car to detect the key (doubt that last part matters).
Post-refresh GT2 so I'm guessing it just wasn't a feature they included for the US...strange because I think other Kia models do include it (at least for windows down), and the Stinger was supposed to be the "flagship".
2023 Canadian GT Elite here.
The window down feature works on my car.
I just hold down the unlock button, and they drop.
A lot of cars have this feature. My old 2002 Nissan Pathfinder had this feature.
