soflo_nick
- Jul 27, 2022
Awesome man thanks for the technical insight! I'm going to go ahead and purchase the afe intake and charge pipe togetherI may not fully agree on that point. Depends on how you define “worth.”
The sound and feel under throttle definitely improved over stock, especially in Sport mode, even with Map1.
Would there be even more gains if I had an aftermarket FMIC? Certainly. What the charge pipes seem to do is open up the channel and make it more regular (less pinches in the bendy bits), which should improve laminar flow and induce fewer places where the pressure has to increase to pass through a restriction, ultimately keeping the air cooler, through it may only be by degrees at best.
Still sounds and looks hella cool.![]()
