Have you replaced anything under warranty on your Stinger?
Front drivers side headlight, Center console, wireless charging pad, Drivers seat top piece, passenger mirror, various trim pieces, The Motor (3.3)
You had the motor replaced?
What was the process like and how long did it take?
I have a 2020 GT-Line. In just a total of 64,000 km (39k miles), rotors were causing a squealing sound, and all four were replaced under warranty. The dynamic bending lights stopped working, and they fixed it under warranty. The fuel pump wasn't working properly and was replaced under warranty. The turbocharger blew at around 62,000 km and was replaced under warranty. All of that was only in 2021. Have you replaced anything under warranty?
did u have bov?
yes, i bought my stinger recently. it has a headlight leak which i did notice at the time of purchase but has gotten much worse at this point and am getting it replaced next week. other than that, nothing!
ABS sensor replaced a few weeks ago, made the dash turn into a christmas tree and the car into a go-kart (no ABS, power steering, stability control, ..). Currently at 88000 km.
Do you know which wheel speed sensor failed? Which corner?
2022 G T-Line 32k drivers door seal warranty from me rubbing against it getting out of the car, getting ready to go in for the roof trim and ask for warranty replacement before I hit the 36k mark,
Nothing here. Could have done the brakes but I decided instead to replace them with aftermarket myself. Now, if a few months I will wait to hear about experience with the 3.3 turbo tube recall before I think about doing it.
Front passenger side headlight. Failed after it became a fishbowl with water.
Yikes! How that happen? Around here is about as humid as it gets, and none of my headlights have that problem. I even ditched the desiccant bags in my '19's headlights and never bothered to replace them, as brand new ones would just saturate and be worthless in a matter of days/wks.
I'm in Florida, so pretty humid. The light had really bad condensation. The desiccant bag only helped temporally. There are probably a broken seal somewhere. The condensation got so bad the light actually failed and I got an error on the dash.
This is a common problem with the face-lifted G70. Many of them had the dealer/Genesis deny warranty coverage because they found small crack(s) on the front lens of the headlight, which they blame for the condensation. I cannot imaging that is the root cause for all of them.
I rarely hear about Stinger headlights having this problem. Glad your dealer took care of it.
IMG_7324.webpIMG_7328.webpThis is a common problem with the face-lifted G70. Many of them had the dealer/Genesis deny warranty coverage because they found small crack(s) on the front lens of the headlight, which they blame for the condensation. I cannot imaging that is the root cause for all of them.
I know a small amount of condensation is normal, but mine looked like a tropical rain forest!
