I think I bled out more fluid than needed, but I used just a little bit of a 3rd 500ml bottle+1 o the motive.. Good stuff. How much brake fluid does it take for a full flush on this car? One 32oz enough?
Yeah the machine at my dealer.Are you asking about an adapter for a pressurized bleeder like the motive one? If so the model number for the Motive cap for the Stinger is 1107.
Otherwise I am not sure what you are talking about because there is no adapter needed to do a manual "2-man" bleed.
Just drill a hole in the cap for an empty water bottle and put a vacuum hose in it. Then you connect it to the valve nipples.
Oh Ok.Yeah the machine at my dealer.
Yes thier is two bleed screws. Search for the thread on proper bleed procedure (it is different from standard).Resurrecting this thread…
For a 2022 GT2 AWD (the “Brembo” brakes - at least cosmetically), are there really two bleed screws (nipples) per caliper?
And are the front and rear the same size/thread pitch?
Asking for a friend.
M10 x 1.0Yes thier is two bleed screws. Search for the thread on proper bleed procedure (it is different from standard).
Thread pitch of the bleed screws?? They were the same size wrench for my 2021, so I would assume it is the same for a 2022.
M10 x 1.0
Speed bleeder SB1010S if you want to replace them.
8 it is, makes one man bleed much easier.So, presuming your 2018 GT2 also has Brembos, you ordered eight of the SB1010S SpeedBleeders?
Just confirming two bleed nipples per caliper and same size front and rear.
Thanks!
Yep. I’ve put SpeedBleeders (and braided brake lines) on everything since my 1993 RX-7.8 it is, makes one man bleed much easier.
Check ball in the screw allows you to leave the screw "open" while pumping the brake fluid.What do these speedbleeders add over the stock bleed screws? From what I can see from a picture, it just looks like it would function the same as OEM.
