MerlintheMad
10000 Posts Club!
^^^Yesterday evening, when I started to gas up, the MPG showed 50.1
. My range after filling up ($5.25/gallon) was 337, so, the car sorted itself out.
AC is only reduced in ECO, per all literature I have read.Does anybody know if the A/C gets reduced in sport mode?
Interesting. My ‘18 GT blows ice cold at idle. I used to have a car that was horrible at idle but ice cold above 1k rpm. 2005 Ford Five HundredOn the topic of AC, I've noticed it blows much much colder when the car is moving vs stop and go traffic. At least on the 4 cyl model. Sure this is to be expected (more air flow over condenser). My old G would blow ice cold just standing still.
What I don't notice is the engagement of the compressor. This wasn't noticeable on the G either, but very noticeable on my old camaro (4th gen), like someone dropping the anchor.
From today's fill up.
Did the unthinkable. Put 87 in... It was $4/gal at the costco in kenosha.
You won't notice the compressor engage. All Hyundai/Kia vehicles use a VDC (Variable Displacement Compressor). The compressor is turning all the time, internally the compressor displaces anywhere from 0 to 100% based on need and isn't clutch operated so you don't feel it kick in.On the topic of AC, I've noticed it blows much much colder when the car is moving vs stop and go traffic. At least on the 4 cyl model. Sure this is to be expected (more air flow over condenser). My old G would blow ice cold just standing still.
I believe they should be sized based on the cabin volume with respect to the BTU requirement.I bet the compressor part numbers are different for the 4/6 cyl models. Probably smaller tonnage/btu.
I would hope so. Otherwise it would be a waste of the higher map/output/tune.These cars are a beast on higher maps.
I just know that map1 doesn’t do much. I blended some 100 with 91 so I was probably about 94 on map 2, still somewhat disappointed. Now that I have E30 on map3, there is a big difference.I would hope so. Otherwise it would be a waste of the higher map/output/tune.![]()
