I've had too much trouble with their caps blowing off or leaking. Finally committed to buying the fancy name brand aluminum set and they are downright dreamy.Still a big fan of the motive power bleeder product. One man device, less chance of damaging the master.
The proper sequence for bleeding or flushing the brake system is to start with the caliper furthest away.I bled mine using one man method. Worked fine. I belive, with brembo, you suppose to start with front passenger side, than move to front driver, rear driver, and rear passenger last.
Check the kia manual for brembo brakes. You'll be surprised.The proper sequence for bleeding or flushing the brake system is to start with the caliper furthest away.
Therefore, bleed or flush in this order:
Rear passenger
Rear driver
Front passenger
Front driver
I'm not disputing you since I haven't checked.Check the kia manual for brembo brakes. You'll be surprised.
Maybe you should. Because this is exactly how kia wants you to bleed brembos on stinger. Idk why, since on every single car i bled the brakes before, i started with rear passenger. Somehow stinger is different.I'm not disputing you since I haven't checked.
I have no clue how. Any particular steps you went by?I bled mine using one man method. Worked fine. I belive, with brembo, you suppose to start with front passenger side, than move to front driver, rear driver, and rear passenger last.
Which cap actually fit?^^The universal caps are junk, but the ones that fit properly have worked well. Bleeding the brakes on the G was completely uneventful, if not for the fact there were 8 bleeders to do (2/wheel).
