Ozstung
5000 Posts Club!
To be honest im willing to try anything as i can't get a wheel alignment to last more than two days. The car has a pull to the left that has deemed to be caused by lowering the car.So, does that mean you have the bushing set installed? What impact do you see on camber over the swing and at what caster settings?
The back springs have come into question regarding how low they sit. It appears they look to be interferring with the electonics and I've had the full diagnostics done .
Kia recommended going back to stock to fix the issue. Got a call from Eibach today who now have my replacement rear springs sourced from Germany. Apparently these sit 5mm higher than the ones i have. They concluded it was indeed a warranty issue in my case.
It was suggested by members on FB that i try the caster adjustment tool, if this helps so be it. I'll advise of how i go.
