RedCal
2500 Posts Club!
Get one of these and put it on his desk
Nearly spat my drink, thanks.Get one of these and put it on his desk
Part of the reason that his times got slower because the engine was probably heat soaked from back to back runs. Turbo's need to be cooled down between passes Having meth helps and so does a bigger intercooler or a chiller on it, but they slow down when they're too hot.Update:
He works from home today lol
I've talked to his colleague and he confirmed me he tried 3 more passes back to back and did worse than his PB of 12.05s on all 3. Apparently he was very pissed and tried very hard on their way home to convince him that it was the track, bad launch, the car's fault, no not really, wasn't 100% there, gave me a slight chance, turbo lag, etc.
Spin the "have a reason" wheels really....
Ahhhhh the Bronx Tale philosophy. I agree...good advice. Now where's Coffeecake?!?!?!? Put him in the f*ckin closetIt's kind of like the Guy that you loaned $20 too and then every time that he sees you, he walks across the street to avoid paying you back. You lost $20 but will probably never have him ask for money again.
This gen is water-air cooling though, so it's much better at that. It's probably still going to have an effect. I doubt it's the turbo, usually it's everything downstream that the turbo is heating, the cylinders, etc. They dump crazy amounts of fuel under boost if you've ever watched a tracking device that can show you real-time mixture or GPH. All of that is to cool the cylinders/pistons.Part of the reason that his times got slower because the engine was probably heat soaked from back to back runs. Turbo's need to be cooled down between passes Having meth helps and so does a bigger intercooler or a chiller on it, but they slow down when they're too hot.
That's not just BMW's but any car with turbo's, especially at the drag strip.
This is just a suggestion, but if Nick is just a straight up jerk and you don't like being around him (why would you if he's that bad) and now he wants to ignore/avoid you, then consider that your biggest win because now you don't have to deal with his mouth.
That's a win in itself!
It Really does make me smile that you got under his skin so much that he's going to have to get a second job to pay for mods on his M340ix just to beat you!![]()
Thanks! I didn't know that.This gen is water-air cooling though, so it's much better at that. It's probably still going to have an effect. I doubt it's the turbo, usually it's everything downstream that the turbo is heating, the cylinders, etc. They dump crazy amounts of fuel under boost if you've ever watched a tracking device that can show you real-time mixture or GPH. All of that is to cool the cylinders/pistons.
Have you dropped it down by a couple of gears before you punched it?Man, this thread has gotten me real exited. I have a new 2022 GT1. First kinda race, roll maybe 50mph, called out by a Lexus, I was like babe I got him, he waved 3, thumbs up, I honked 3 times then punched it!!!!. Serious lag, he left me, torque finally kicked in. He gapped me by half a car. I didn’t know what Lexus it was… my first race and loss.
Research alot on the jb4 piggyback tune for starter.
Would easily gap any is-f.
Thats true. But modded to modded, stingers should walk one. Lexus beyond a exhaust mod costs an arm and a leg so doubt most would be supercharged lolRCF should be a monster on the highway. It's a little quicker than the Stinger from a stand still but their extra 100 hp should make quite a difference at highway speeds where traction isn't as important.
A stock Stinger losing from a 50 roll to a RCF is an acceptable loss.
Roll races are not really our territory. Stick to digs (standstill) and you'll have most people wondering why they're getting owned.Man, this thread has gotten me real exited. I have a new 2022 GT1. First kinda race, roll maybe 50mph, called out by a Lexus, I was like babe I got him, he waved 3, thumbs up, I honked 3 times then punched it!!!!. Serious lag, he left me, torque finally kicked in. He gapped me by half a car. I didn’t know what Lexus it was… my first race and loss.
Wrong car. RC-F is 470's HP and 390's TQ (Crank #'s). Piggyback ain't gapping this at all lol. Another thing, it traps 112 stock......much higher than our platform. Always know what you're up against if you want to avoid a trip to Gapplebee'sResearch alot on the jb4 piggyback tune for starter.
My bad, totally thought I read IS F lmao.Wrong car. RC-F is 470's HP and 390's TQ (Crank #'s). Piggyback ain't gapping this at all lol. Another thing, it traps 112 stock......much higher than our platform. Always know what you're up against if you want to avoid a trip to Gapplebee's![]()
This^^^. If you just floor it at 2k rpms your gonna have some lag and it can actually be bad for the engine. The goal is to be right in your power band. Drop a few gears to get your rpms up to 4000 then punch it and manually upshift at 5600 rpm. Makes a WORLD of difference. You’ll be surprised how hard and quick the car pulls in that rpm range. Not saying you would have beaten him, but if he only beat you by a half a car, it would have been neck and neck. Nowwwww if the Lexus knew how to drive his car, it wouldn’t matter either way against a stock Stinger. No shame in that loss at all.Have you dropped it down by a couple of gears before you punched it?
How would that be bad for the engine?This^^^. If you just floor it at 2k rpms your gonna have some lag and it can actually be bad for the engine.
From what I understand, and please correct me if I'm wrong, you don't want to put too much strain on the engine in low RPMs. I was always taught with turbo engines, Heavy load (on the engine) you want High RPMs. I guess it's called LSPI ( Low speed preignition). It's basically lugging the engine. I don't have a ton of auto knowledge, so If I'm wrong please correct me. This may only occur with manual transmissions as automatic transmissions will down shift automatically but I'm not sure. If I'm wrong just tell me to pound sand lolHow would that be bad for the engine?
