Mudpupy
Have any of you purchased and installed an M&S splitter from KDM Warehouse? I received mine today but it has no instructions as how to mount and there are no pre drilled holes to go by. Anyone have this problem?
They aren’t predrilled.Have any of you purchased and installed an M&S splitter from KDM Warehouse? I received mine today but it has no instructions as how to mount and there are no pre drilled holes to go by. Anyone have this problem?
Thanks for your reply, but I'm not taking the front end off to mount this splitter. It should have pre drilled hole's or at least a template of where to drill. Sal at KDM is working on getting me some info now. Thanks ArtThey aren’t predrilled.
it only mounts one way. You look from the back on where the best place to drill / bolt it in place. And you use tape / clamps to hold in place (with the front end off the car)... then drill. Then use the bolt/screw to hold in place.
It takes 5 minutes. By yourself.Thanks for your reply, but I'm not taking the front end off to mount this splitter. It should have pre drilled hole's or at least a template of where to drill. Sal at KDM is working on getting me some info now. Thanks Art
Supplied double sided tape and bolts.don't you use some sort of caulk/adhesive as well?
I bought the gloss black one, it has a very good paint job on it. Has been on the car for 2 months now, I love it, I just back in all parking spaces now so I don't take a chance of rubbing or knocking it off on a curb.Did you buy the gloss black one, or have it painted? How long have you had it on and how is it holding up? (It's on my wish list )
No chips, I'm sorry but I don't know what PPF is?No chips or did you PPF it?
