The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
What are the size of the tips you used inlet and outlet size , and where did you get them ?Went with the Akropovic style round tips. They required some grinding of the bumper to fit. They are attached to the Borla cat-back system. The grinding was not visible at all.
Overall, very happy!
View attachment 53916View attachment 53917View attachment 53918
ThanksPurchased them from a member on the forum 51mm X 89mm. Fit the Borla system perfectly.
I just like the stock ones :b thank you for all the 46 pages of RnD![]()
This is my first car with 'proper looking' chrome exhaust tips =bDitto
find a different shop. they can adjust the mufflers at the clamps to the next section of pipes. I didn't have to cut anything and the MBRPs, if undamaged, should line up with the bumper cutouts perfectly.Hi I am having a problem with installing tips. i bought MBRP exhaust tips. I went to my local shop and he said the MBRP exhaust isn't lined up with the hole tips on the diffuser. If he put the tips on he said the tips would be hitting the bottom diffuser.you might have to cut the bottom part. im wondering why can't he lift the exhaust up? Maybe not enough room? i got the correct size tips for the MBRP. Has anyone installed tips on MBRP? What can I do in this situation?
Oval or around?Hi I am having a problem with installing tips. i bought MBRP exhaust tips. I went to my local shop and he said the MBRP exhaust isn't lined up with the hole tips on the diffuser. If he put the tips on he said the tips would be hitting the bottom diffuser.you might have to cut the bottom part. im wondering why can't he lift the exhaust up? Maybe not enough room? i got the correct size tips for the MBRP. Has anyone installed tips on MBRP? What can I do in this situation?
Oval 63x105. I went to another shop. He said he can work it out. im not sure what clamps snowwhite I'd talking about.Oval or around?
Oval needs to be 63x105 no issues, no trimming.
round is 63x89 bumper needs to be trimmed
make sure these are parallel to the ground, should not have any issues with the exhaust tips into the tips.
He's talking about the clamps on the rear section of the exhaust. You can loosen them and adjust the pitch of the rear mufflers and tips so that they line up nicely in the diffuser openings.Oval 63x105. I went to another shop. He said he can work it out. im not sure what clamps snowwhite I'd talking about.
I have the original exhaust, what is the original inlet size in your opinionPurchased them from a member on the forum 51mm X 89mm. Fit the Borla system perfectly.
Are you talking about the stock exhaust?I have the original exhaust, what is the original inlet size in your opinion
YesAre you talking about the stock exhaust?
TnxSorry I didn't take those measurements so I really have no idea =(
Why would you want aftermarket tips for the stock exhaust?
