I am looking for replacement rims for my up coming Stinger. Has anyone seen if the rear rims are different size to the front. What is the offset size ET35?. The stud 5/114.3? Not sure if we have covered this already.
Better than the running gear of the Apple Genius I saw last week.Thanks Bamm I am pritty sure it's the same running gear as the Hyundai Genius. But still can't find any info on the offset sizes.
I was thinking of doing the same thing. Design-wise, the wheels on the GT spec are the weakest part of the car (to my eye). The A5 Sportback was an option until I sat in the back seat(which is cramped to say the least), but the S5 wheels are gorgeous. I'd love to get something similar for the GT.Sticking with 19 inch rims so I can just swap to tyres over.
Here is all the info that I have seen to date:
This could change so I would not bank on it until the car is released.
- 8.0J×19 (front) / 9.0Jx19 (rear)
- Bolt Pattern: 5x114.3
- Hub Size: 67.1mm
I am hoping for a little advice on a second set of wheels, particularly as the availability in the US is scheduled to start with the need for winter tires on a GT 2 (?) in the northern climes.
Below are the wheel and tire specs from the owners manual and here are specs for 4 wheels I have available from my 2013 Mini Countryman 4S.
I am wondering if these would be compatible/acceptable given the Kia specs-GT 2 preferred. To me it looks like front maybe yes, rear maybe not, but I'm not sure about the offset and and not expert on wheel details.
- Size: 19x8.0
- Offset: +45 mm
- PCD: 5-120mm
- Bore: 72.5mm
- Lug Opening: 14mm Conical Seat
Also wondering if anyone has seen the spec for "ground clearance"?
Thanks for any advice you have.
View attachment 1083 View attachment 1082
I don't believe the bolt patterns match. So they would not fit.
I don't recall seeing any specs for ground clearance.
i have a wheel shop finding some wheels for me right now. ill post pics and info once its all doneFrom what I have read on this thread, nobody has studied the wheels on the 2 Stinger built for Sema 2017. OEM GT2 wheels are unsatisfactory width, front and rear.
Is the hub size the same on the 18" rims?Here is all the info that I have seen to date:
- Hub Size: 67.1mm
I can find those sizes in 18".
I suggest you have a look at this thread:
https://stingerforum.org/threads/heads-up-re-winter-tire-package-kia-canada.1055/#post-9233
While it deals with winter tires, it also deals with fitting 18" rims over the Brembo brakes! Good luck.
Can you put the same size tires on staggered rims or noI was thinking of doing the same thing. Design-wise, the wheels on the GT spec are the weakest part of the car (to my eye). The A5 Sportback was an option until I sat in the back seat(which is cramped to say the least), but the S5 wheels are gorgeous. I'd love to get something similar for the GT.
https://mediaservice.audi.com/media...AQBSsVRw5AQAAA?cropN=-0.01,0.055,1,1&wid=1800
