celwin
Like the subject says. If using 5mm spacers, does one need to replace the OEM studs with extended ones? Or are the OEM lugs long enough to accommodate securely tightenning lug nuts to studs with 5mm space installed? I see a few people have mentioned using 5mm spaces; But none said if they used extended lugs or OEM ones.
