.....................WTF , you cut outside the lines , youre in trouble at craft shop:laugh:
That was on purpose, I needed the template to be about 1/4” larger in that direction so I used a sharpie to extend the line.
............and you're making ?????
in process
If Symetry and Balance was the goal you are over loaded on the right side.
I’ve never been a fan of using other brand’s badging on a car. The 4S is clearly a Porchse badge. Also none of the fonts match. It’s the main reason I took the GT off when moving the Stinger script to the center on mine. It’s in a totally different font than the Stinger logo.
But if you like it, you do you.
Actually Porsche use 3 different fonts on some of their models but somehow it works , Im fine with it though
Here's what the UK GTS looks like uks.webp credits to Mbro for the pic ,
I think it would look better with just "Stinger" on it. Less is more.
The ol Black the lamps trick! Ok, not a big fan of it and in oz you get fined.
Technically it’s just tinted so the light still shines through fine. Luckily we don’t have to worry about getting ticketed for that here.
Looks good man. You tint it yourself? Did you tint that side reflector as well?
I noticed that too but I think it’s because the box I added to block the plate is slightly crooked.
I’m still trying to decide if I like the smoke, if I keep it I will likely do the reflectors too.
When I was trying the deletes , I did the sides as well but ultimately felt they added a proprietary degree of originality and helped accentuate the length of the car , try it and see what you think . I like the tint on the tails .............
Yeah I just got some tint vinyl off eBay and made templates with painters tape. Still trying to decide if I like it.
I didn’t do the side markers. They entegrate with the tail lights that wouldn’t be tinted too much and I think it would look odd.
Not my thing at all, including the stinger logo. But if that's your thing, rock on!
