westcoastGT
5000 Posts Club!
.....................WTF , you cut outside the lines , youre in trouble at craft shop
.....................WTF , you cut outside the lines , youre in trouble at craft shop![]()
............and you're making ?????That was on purpose, I needed the template to be about 1/4” larger in that direction so I used a sharpie to extend the line.
Actually Porsche use 3 different fonts on some of their models but somehow it works , Im fine with it thoughIf Symetry and Balance was the goal you are over loaded on the right side.
I’ve never been a fan of using other brand’s badging on a car. The 4S is clearly a Porchse badge. Also none of the fonts match. It’s the main reason I took the GT off when moving the Stinger script to the center on mine. It’s in a totally different font than the Stinger logo.
But if you like it, you do you.
I like it , it looks like the Stinger badge is crooked though ?? I think you should delete the rear red deflectors too Good job
When I was trying the deletes , I did the sides as well but ultimately felt they added a proprietary degree of originality and helped accentuate the length of the car , try it and see what you think . I like the tint on the tails .............I noticed that too but I think it’s because the box I added to block the plate is slightly crooked.
I’m still trying to decide if I like the smoke, if I keep it I will likely do the reflectors too.
Looks good man. You tint it yourself? Did you tint that side reflector as well?
