cjbigcog
Road trip....you never know...Were you going for some kind of record or something?![]()
The car lovers social network
Automotive components
Automotive Hot or Not
Explore Pet Insurance!
Vehicle hacker protection
Advertise with us!
Timing is everything
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
The Food Order Method
Advertise with us!
Promo code: REDLINE
Authentic Tuning
I wish there was not 3-4 different red colours under the hood in this pic.Installed a set of Add W1 Blow Off Valves.
I had to trim my SXTH Element Catch Can GT bracket (which really hurt to do!) to get them to fit. Good thing I have an extra bracket in red just in case.![]()
I wish there was not 3-4 different red colours under the hood in this pic.![]()
My girlfriend's Jeep just got a nasty bullseye last week. I tried one of those Permatex brand windshield repair kits that AutoZone sells and it actually worked surprisingly well. It's probably 90% invisible now. I was most worried about just stopping it from extending further, but she's so happy with the final result she isn't even bothering with new glass. Maybe give that a shot.
***Sorry for the beginer question here...***Oh damn, I missed this a long time ago, but I only got this sorted out over the last couple of weeks, so maybe good that I didn't reply until now.
I had one set of Whiteline front endlinks on until recently, they got really squeaky through the winter, I don't know if they were just defective or if something else was going on.
But I digress, they kindly sent another set for me to get fitted, and we wanted to be 100% sure they were properly installed, so we put it up on the hoist, swapped the endlinks, then got it on the alignment machine so that we were under load and could adjust. There doesn't seem to be a huge range of motion in the ball joints on the whitelines, you really can't install these solo in your garage by the instructions they send. Also worth noting that the nuts on the turnbuckle come loose pretty easily and need some loctite to keep them in place.
Once you've got them on an alignment machine, get one person in the car, and have them turn the car left, right, left, right, left, right, each time checking that you have a full range of motion and that the end link doesn't bind, make an adjustment, rinse and repeat, then loosen, add loctite to the nuts, and tighten them down again. If the ball joints had a larger range of motion I don't think this would be a problem, but it seems like they only just fit with the turnbuckle aligned just right.
Right now I'm not having any problems which is a huge relief.
It’s doable, but will take much longer. You need an Allen wrench to keep the post from spinning and a 17mm short wrench to get enough turns to loosen it, then you can turn the rest of the way with your fingers.***Sorry for the beginer question here...***
How hard would it be to switch the WL Endlinks from soft to stiff at home, without lifting the car? Is it doable? Seems pretty straight forward to me, right? Untighten the bolts, place it in the stiff holes, tighten the bolts and that's it?
Sounds like fun. Post an update about the Maxton kit. I'm interested to see how easy (or not) it installsOrdered Eibach sway bars, front and rear, and a set of snorkels. Need a weekend off work, ha, to install them and the rest of my Maxton kit.
That steering wheel looks awesome! Curious about your shifter, what is it?
Hyundai Elantra/I30 N and N Line.That steering wheel looks awesome! Curious about your shifter, what is it?
