New Fella rotors introductory price!!
Status
Not open for further replies.
NYdito
Bronx NY
Fella brakes
Hello guys this is a new option for the stinger community with an introductory price to start off. You could order an entire BBK or just rotors. First two options are rotors only front or rear. Other two options are front BBK or rear BBK.
Contact them directly and ask for price.
2-PIECE FLOATING DISCS
Our Fella Brake 2-Piece Discs are engineered with the highest quality materials and maximizing weight savings.
Each 2-Piece Disc consists of a center bell manufactured with 6061 aluminum and slotted discs standard with drilled and drilled/slotted optional.
The lighter weight allows for less rotational mass which equates to faster overall brake performance and handling.
6 PISTON MONOBLOC CALIPER
Our complete Fella brake kits offer shorter stopping distances, better brake modulation, firmer brake pedal, and less brake fade compared to the original factory equipment. With a choice of 4 or 6 piston calipers and a disc range of 350-420mm, our fitments are designed with the vehicle’s performance needs in mind.
Each Fella Brake kit includes a pair of calipers, discs, brake pads, brackets, Hel Brake lines, and all necessary hardware. All Fella brake applications can be found on the link below.
Material: AL6061 Cast
Construction: Monobloc
Pistons: 6 total (2*40mm, 2*36mm, 2*36mm)
Disc Sizes: 360-420mm x 34-36mm
Weight: 3.4kg
Finish: Black, Blue, Red, Yellow
Sweet link me
What is the actual weight of the front rotor?
Does price include shipping.?
Sweet link me
Should have link by tomorrow.
Funny you ask I gave them a list of info I need including weight just waiting on answer.
Yes and again this is only the introductory price it’s going to go up. Instead of doing group buy and making everybody weight it was better to give the discount to the first few orders.
So, for $3K, how much better is this than the OEM Brembos? Will they clear 18" wheels?
Also, is this like the custom Subaru kit that came out for the Legacy GT a couple of years back? Similar to this - good intro price, but then after a couple of years, pads were impossible to find. So people who bought one could one get one pad life-cycle out of it, because there were no other options.
Don't get me wrong, I appreciate choices - but I've seen people burned before with one-off brand BBKs that ended up being orphaned pretty quick..
I assume you can use the 2-piece rotors with the OEM Brembo calipers?
This is for people that would like to change the entire system from a 2 pitón to a 6 pistón also two piece and new lines. Depending on wheel size and offset. Pads you could use deferent brands. That’s why they gave the rotors options only also you don’t want to spend as much.
Correct this would be the cheapest option we have at the moment the other company has it at $800.
Are you selling this or someone else?
I put the link so you could by directly from them.
Or you could pay less & get genuine from South Korea
2018+ Stinger Factory Brembo Brake Kit
That what we have here in the US. This is for people that want a deferent set.
We are brining more options to the table before complaining about price see the current options we have at the moment and do your research. This is why other manufacturers don’t want to invest in our platform if you don’t like or don’t agree with the parts just move on not a problem.
So are you selling these?, because your promoting them like you are.
But why would people pay more money for a brake set upgrade that’s not a known brand, when you can buy an OE Brembo set that actually fits the Stinger for less money.
Not me look my post up I have always looks for more options for us. Why the question you want to send me some cash?
It’s a forum, people ask questions on forums & sometimes you may get answers to your questions.
Do your research I had to change my oem two times less then 17 and again soon. If you are asking this question then it’s not for you. Stop highjacking thread let’s keep it to the subject. That’s like me asking you why you changing wheels for more money if the oem are good. Because I want to. Funny people in this world.
I don’t have to do any research, I asked a question & your getting defensive, that tells me something.
I do what I want to my car, I’m not on here selling stuff, you should go through the admin for approval, what do you think Sal @Kia Stinger
Lol nobody getting defensive but looks like you don’t know much of why people change brakes. I’ve done 3 group buys with cquence ask around or use search bar.
Weight of rotor
1) 6p - 380mm / 10.42kg (23.0lb) $750
2) 4ps - 380mm / 8.89kg (19.6lb) $650
3) 4ps - 350mm/ 7.64kg (16.8lb) $650
4) rear 4p - 380mm / 7.73kg (17.0lb) $700
We’re questioning your motives.
Most of your posts on this thread come across Not like a member saying “hey, these are available now to buy as a FYI”.
This is sounding like a vendor with skin in the game (commission). Or perhaps your are advertising on behalf of Fella (or whoever the vendor is) for free parts yourself.
either way, that’s sketchy and seems to violate the rules.
Understood look me up that way you see the other past group buys I’ve done always save people money. Not everything in life is bad enjoy a discount part or pay regular price your choice. Im always pushing other manufacturers to make parts for us but stuff like this makes them not want to do it not everything is a conspiracy. Looks at the cquence, seibon, spoiler King, JB4 group buys we did in the past.
I have the base 2.0 model and the Kia dealership told me I can't get the Brembo brakes and it only comes with you order with the car. Do you know if this will fit my 18inch wheels?
If you know the wheel offset info I could find out.
I guess that was my question - do these use OEM sized pads? If so, that's definitely a major plus - although, then the only difference is 6 piston vs 2 piston? I already did SS lines..
Status
