NYdito
Fella brakes
Hello guys this is a new option for the stinger community with an introductory price to start off. You could order an entire BBK or just rotors. First two options are rotors only front or rear. Other two options are front BBK or rear BBK.
Contact them directly and ask for price.
2-PIECE FLOATING DISCS
Our Fella Brake 2-Piece Discs are engineered with the highest quality materials and maximizing weight savings.
Each 2-Piece Disc consists of a center bell manufactured with 6061 aluminum and slotted discs standard with drilled and drilled/slotted optional.
The lighter weight allows for less rotational mass which equates to faster overall brake performance and handling.
6 PISTON MONOBLOC CALIPER
Our complete Fella brake kits offer shorter stopping distances, better brake modulation, firmer brake pedal, and less brake fade compared to the original factory equipment. With a choice of 4 or 6 piston calipers and a disc range of 350-420mm, our fitments are designed with the vehicle’s performance needs in mind.
Each Fella Brake kit includes a pair of calipers, discs, brake pads, brackets, Hel Brake lines, and all necessary hardware. All Fella brake applications can be found on the link below.
Material: AL6061 Cast
Construction: Monobloc
Pistons: 6 total (2*40mm, 2*36mm, 2*36mm)
Disc Sizes: 360-420mm x 34-36mm
Weight: 3.4kg
Finish: Black, Blue, Red, Yellow
Weight: 3.4kg
