What setting do you like?It feels the way you think it should feel throttle response much more on tap. Sometimes when I'd have to do panic accelerations pulling out you almost think something's wrong with the car because it takes so long for it to respond. It gives you the feeling that you have a lot more horsepower than you did before. Honestly it feels like it does more than just change the percentage of throttle input it feels like it actually changes a lot more than that with acceleration.
I have not had that problem. Actually got myself in trouble sideways a few times. The setting I am looking for on the petal timer is direct throttle to throttle body action.I'm the type that'll just go straight to the most aggressive and leave it there there's no reason to have it anything less than. Maybe the only reason is if somebody else was driving my car it's a bit touchy in certain circumstances but you get used to it. What I want to know is I have anti-skid anti stability turned off and it still does the same thing when you lose traction it cuts the motor out what the f*** what's the point of turning it off if it still does the same damn thing
This is exactly what I'd prefer too, removal of the drive by wire delay versus remapping the actual pedal input.I have not had that problem. Actually got myself in trouble sideways a few times. The setting I am looking for on the petal timer is direct throttle to throttle body action.
I beleive the tuner can act very close to that. The question is what setting will have a direct relationship with petal and throttle body.This is exactly what I'd prefer too, removal of the drive by wire delay versus remapping the actual pedal input.
Yeah I suppose I need to look into a specific weighted spring because they are specific links for the kickdown for the TVS cable on transmission. I've talked to the mechanic before and they said don't mess with it. But I'm going to discuss it with him againCan't you get a smaller/weaker spring in your El Camino??
Looks interesting.No plans for that.
On the JB4 you'd want the JB4, fuel wires, and data cable or JB4 mobile depending on how you want to connect for updates.
2018 Kia Stinger JB4 Tuner | BurgerTuning.com
Looks interesting.
What would the total price be have it packaged and shipped to sweden?
And is there a posibility to mark down the item price on the package? (Because in sweden the items total price goes up between 30-50% importing outside europe)
I did too I think I didn't connect it properly and run through the calibration set up the way it was supposed to be I missed something. I took it out reinstalled it again and went back over everything and then no problem. you may want to go get that deleted out of your car cuz that will show up if you ever take it to the dealer and they will wonder why you had a loss of power to your throttle.Just installed my pedal tuner. I followed the directions on the back of the box and could not calibrate. Pulled up our wonderful forum and saw the calibration video. Push mode button to save. I do like it much more response throttle the way I think it should be. I ended with orange setting in the middle (no + or - light). Tested settings in sport mode then reverted to comfort and for me feels perfect in both modes. I did get a dash light on my first drive then after stopping and restarting the car it went away. Anyone have an Idea why this happened and will it come back. Other than that fine product from BMS. As long as the dash light stays off I definitely reccomend If you want a better throttle response. Many settings, a setting for everyone.
Ok sweet must have been when not calibrated properly. I second guessed this purchase several times but in the end very happy.If the ECU is awake when you unplug the gas pedal or if you operate the car without it calibrated can trigger a one time light. No big deal.![]()
